SERT Dyno Tuning
Old Oct 21, 2006 | 11:27 PM
2005flstfi's Avatar
2005flstfi
Default SERT Dyno Tuning
Is it possible to set up a SERT reasonably accurate without using a dyno because my harley dealer does not have a dyno and he reckons he can get it to run properly downloading data from other bikes that have roughly the same set up as mine and then fine tune it from there.
Old Oct 22, 2006 | 01:15 AM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
Default RE: SERT Dyno Tuning
anything other than a slight muffler change as in slip ons, NO IT IS NOT POSSIBLE
Old Oct 22, 2006 | 10:20 AM
msocko3's Avatar
msocko3
He won't be able to get it dead on but he'll get it close if he rides it and uses the Data Mode feature. When I say close I mean it won't be lean and it shouldn't ping.
Old Oct 22, 2006 | 12:03 PM
One_Screamin_Eagle
ORIGINAL: msocko3
And he won't know if one cylinder goes pig rich and he won't know where his air fuel is etc etc. On a delphi bike, one cyl tends to begin to breathe when the other slows down. Look at the ve tables and you will see that it would be a mistake to do anything other than simple slip on change or air cleaner and think you can map it by riding around.
Westy
Jun 23, 2010 08:24 PM
crock921
Aug 28, 2007 08:18 AM
sparky_mo
May 16, 2007 10:25 AM
sws1
May 10, 2006 09:48 PM
twohats
Feb 13, 2006 06:04 PM
