Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I'm new to this SERT programming thing and could use some info.
Bike is an 07 FLHX w/103, flat-tops, and 255's.
On the advanced setup (their map for this setup) for AFR it has preset readings of mostly14.6 in midrange of map. My question is can these settings be changed and what would a better AFR reading range be?.
