Battery Drain
Old Jul 6, 2011 | 07:13 PM
NC_Grover's Avatar
NC_Grover
Default Battery Drain
I have a 92 electra glide and something has been draining the battery if i don't ride it for a couple days. I have replaced the stator, wich was bad, and the regulator. Problem was still there. The horn hasn't worked since i got the bike a couple months ago. I checked the wiring with a volt meter and the wiring seems to be good so i replaced the horn with a new one from jpcycles.com. The new horn doesn't work either and i noticed that when i hit the horn button the volt meter on the bike goes to zero. I disconnected the horn last night and now there is no more drain on the battery. How could just the horn be causing the battery to drain? Another question is there is no markings on the terminals on the horn as to which is positive and negative. So could hooking it up backwards have caused the drain? Any ideas, help would be greatly appreciated.
Old Jul 6, 2011 | 08:16 PM
nvsteve's Avatar
nvsteve
A common problem is loose or dirty connections on both ends of the battery connections.
Old Jul 7, 2011 | 09:13 AM
NC_Grover's Avatar
NC_Grover
If the battery terminals were the problem then i would still have an issue with loosing power on the battery.
Old Jul 7, 2011 | 10:05 PM
Little T's Avatar
Little T
Have you done a current draw test with the key off?
Old Jul 8, 2011 | 04:51 AM
henryb's Avatar
henryb
Stage III
May be due to not enough charged the battery so by this reason also battery loose power so check it and if so then charge the battery.
Old Jul 8, 2011 | 06:53 AM
NC_Grover's Avatar
NC_Grover
The battery charger shows full charge on the battery. Volt meter showed 13.5 volts on the battery. Not sure how to do the current draw test.
Old Jul 8, 2011 | 10:06 AM
Little T's Avatar
Little T
Hook in series with a multimeter on the negative side of the battery cable. Then check how many milli amps you are drawing. Anything over 50 is excessive. Unplug components to see what causes the most draw
Ross McDonald
Oct 18, 2019 05:35 PM
Born4Booze
Electrical/Lighting/Alarm
Mar 20, 2017 10:34 AM
kingxirol
Sep 8, 2015 02:16 PM
CISO1969
EVO
18
Oct 24, 2013 02:49 PM
Sportster313
Jun 25, 2013 12:02 PM
