PCV auto tune ignition trim values
Old Aug 7, 2011 | 09:08 AM
dgoering's Avatar
dgoering
4th Gear
Default PCV auto tune ignition trim values
Does anyone know if the values table for ignition trim for the PCV should all read zero?
My base map had 3's and 4's when i loaded it, all were at the higher end of the throttle position and subsequently at higher rpm as well.
After first riding session i accepted the trims and then i noticed the ignition values table all read zero..
Normal?????
Old Aug 8, 2011 | 03:09 AM
Watch Guy's Avatar
Watch Guy
Default No, not normal
Of all the things the AT does, it doesn't make unwanted changes to the timing columns.
Old Aug 13, 2011 | 08:06 AM
dgoering's Avatar
dgoering
4th Gear
Thanks again Watch!! And by the way, i love my power duals as do you.
Just trying to get a few tank fulls in to get the auto tune dialed in.
I am very happy with the way this bike is starting to perform ...
Dont know really what else i can do to it, without cracking open the motor..
It dyno,d at just over 100 hp and 102 tq.
All weve done is se 255 cams, lifters, and pushrods, vh power duals w/twin slash rounds, standard baffles, pcV with auto tune.
Thanks for all your help...
stan60
Aug 13, 2013 07:35 PM
Gunnysgt
Aug 1, 2013 03:26 PM
tekeum
Jun 14, 2010 04:42 PM
Puttnutt24
Jun 10, 2010 07:32 AM
rebman76
Jun 6, 2009 05:49 PM
