looking for a map for powercomander
Old Nov 27, 2006 | 01:57 PM
sgreen1456's Avatar
sgreen1456
Default looking for a map for powercomander
I have an '04 Deuce with V&H big shot staggered(w/baffles) and se air filter set up...no ecm flashes. I need 2 maps, first one with this set up and 95" BB kit to run and get rings seated. Then a map fot this plus the se pro heads(16952-99C) -with flat tops,will yeild 10-1 cr. And andrews 37G cams advanced 2degrees. Hope someone out there has the maps to get me close as theres nothing on the powercomander site for this (have talked to them and nothing at all for these heads) The closest dyno tuner for powercomander harleys is 2 1/2 hr drive from me and want to get the rings seated somewhat cause i know cyl pressure should increase afterwards and probably change map requirements and to run some to make sure everythings ok after changeing cams and heads. dont wanna tow that far for dyno only to find out i have some problem preventing the dyno tune.
Old Nov 28, 2006 | 03:34 PM
sgreen1456's Avatar
sgreen1456
Default RE: looking for a map for powercomander
Is there no one out there running a 95" motor and andrews cams with a powercomander?
Old Nov 29, 2006 | 04:00 PM
itsmyforte's Avatar
itsmyforte
email the guy at fuelmoto, i bet he has something u can use.
Old Nov 29, 2006 | 04:30 PM
sgreen1456's Avatar
sgreen1456
Just did, thanks....been searchin for databases on the maps...hard to find and no one replies to posts askin for info. why is it so hard to get a map to put me in the ballpark? and yes i know i will need to have it dyno tuned afterwards but just wanted to same some $$ and get rings seated before i take it in, dont wanna shell out that much cash to have it done twice....again, thanks
adm
Jul 12, 2022 11:54 AM
Big Money
Jun 26, 2015 06:03 PM
RedGlide12
May 29, 2014 05:57 PM
siggyone
Jul 28, 2012 10:08 PM
wickeds10
Apr 8, 2010 11:08 PM
