Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
The tuning device (TTS) is yours. You payed for it and it is expensive. Take a few buddies with you if you are uncomfortable going by yourself but go get it. The kid will cough it up or you can call the Sheriff and have him charged with theft.
Doc's # is 352-404-6999
If the exhaust is in a bind then it will vibrate the frame. Loosen all nuts and bolts. Move the exhaust around a little to find a sweet spot. Tighten up the head exhaust nuts a little then bolt it to the frame but do not tighten, just snug it up. Tighten the head exhaust nuts to spec then finish with the frame bolts. Just need to center the exhaust system so there is no bind.
Just checked every inch of the exhaust and it doesn't bolt to the frame. Only to the heads and transmission. All off the frame.
