Can't open headlight?
Old Dec 27, 2011 | 06:19 PM
pinchepunk's Avatar
pinchepunk
Stage II
Default Can't open headlight?
I purchased an aftermarket headlight that I was told was made for Harley Davidson motorcycles but for the life of me I can't get it open (it didn't come with any wiring).
Below are pictures of the headlight. The only thing that I've been able to do is remove the front out ring and a hex-head pin screw that was embedded into one of the small holes on the bottom (visible in pics). The inner ring around the lens has three circular indentations and I can move it around, although tight, but it doesn't seem to be going anywhere.
Unfortunately, the seller hasn't been able to tell me how to get it open either. I'm hoping someone here has run across the same headlight and can help me out. Below are a bunch of pictures that I hope will help.
Thank you in advance, I really appreciate the help!
- Jean Marc
Old Dec 28, 2011 | 06:44 AM
UltraNutZ's Avatar
UltraNutZ
that front trim ring should unscrew and the lens with the bulb will slide right out.
Old Dec 28, 2011 | 11:29 AM
pinchepunk's Avatar
pinchepunk
Stage II
I removed the outer ring, there is an inner ring that you see in the pics but no matter how much i turn it doesn't seem to go anywhere.
The lark
Touring Parts
May 14, 2019 01:34 PM
MidnightFLHX11
Touring Parts
Oct 31, 2017 04:13 PM
Zim
May 6, 2014 04:23 PM
timberwolfz28
Apr 24, 2014 01:18 PM
CJinNH
Dec 23, 2010 08:34 PM
