Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
If yourworking on pre-ignition. I wouldselect "Knock Retard Front"and Knock Retard Rear" for two of the selected items to graph then zoom in on any knock activity. Other wise I monitor Throttle %or MPH.It'll log over 30 minutes of data so need to rush.
My knock was on the Front Cylinder and only while cruising at lower RPM whileunder minimal load. Not something that is easliyduplicated on a dyno or isolate to one cylinder with other EFI tuners.
Thanks. This isnew to me but after reading the manual two times it all makes sense to me. I appreciate the advice. I don't think I have anything bad wrong with my "out of the box" file but why not find out for sure since I've bought the technology.
I need a PC111 ignition map for my Roadking. the mileage sucks with the ecm timing. I need a full page print with all the blocks filled with the correct numbers for all throttle positions. Then I can download the info into my PC111,,,,,,,thanks
