Need PC III USB Map For '04 FLHTCUI
Old Dec 30, 2006 | 06:41 PM
fhartell's Avatar
fhartell
Stage II
Default Need PC III USB Map For '04 FLHTCUI
Looking for a PC III USB map for TC motor w/ the following mod's:[/align]'04 FLHTCUI
PCIII USB
Ness Big Sucker II Intake
Rinehart True Dual Exhaust
SE Big Bore Stage I Kit
SE Pro TC Performance Heads
SE 257 Cam
Anyone have a map close to this I'd be greatful. The HD Dealer is afraid to Dyno & Map it because it was just installed.[/align]
Old Dec 30, 2006 | 10:22 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Need PC III USB Map For '04 FLHTCUI
Any tech in their right mind would be insane to dial it in at this point...... It is a fresh build, correct?????
Mapping is one thing, but loading it on the dyno, not the best thing to do to a fresh top-end.....
Get 500 miles on it before you start thrashing it on a loaded drum......
As far as a map, if someone has a 1550 High Output map, that is what you need......
Get the HD 1550 HO flash, and dial it in from there, cause if your PC craps out while you are on the road, it won't run worth a crap (Like now)....
At least you will have a fighting chance with a "Fall-back" map, if that were to happen....
SERT map 105HB105 would be a perfect starting point, but as you have a PC, that suggestion is for naught......
SnoRider
Aug 22, 2016 03:21 PM
tdshepard
Jan 26, 2010 09:41 PM
srob
May 9, 2007 09:35 PM
SMSgt B
Mar 25, 2006 06:21 AM
05 FLHTPI
Jan 26, 2006 10:14 PM
