codes 24 & 25 ignition coil problems
Old Apr 20, 2012 | 03:25 PM
kujo's Avatar
kujo
Stage II
Default codes 24 & 25 ignition coil problems
I have a 2001 electraglide,,I had it serviced for the ignition switch malfunctioning. When I got it back the check engine lite was still on. I did the code search and came up with the numbers 24 & 25, front and rear coils. I did a check on the coil per shop manual and it is in specs. The bike runs fine. Any other thing I should be looking at and How does one clear the codes? The stealership says it needs to cycle through 50 times,which I'm pretty sure it has, .... Any ideas out there would be helpful what the issue(s) maybe....
thanks
Kujo
Billy North
Sep 12, 2016 08:34 PM
97stalker
May 12, 2016 09:40 PM
Steen
Feb 5, 2016 05:44 PM
mesmarter
EVO
11
Aug 14, 2013 06:24 PM
