Backfire then wont start
Old Apr 21, 2012 | 12:33 PM
Deuce Meanmachine's Avatar
Deuce Meanmachine
Stage I
Default Backfire then wont start
Hi guys I'm new on HD FORUM. Question for you. I stored my bike in a HD store back here in Montreal, Canada. a week ago I've put 1,000$ on it to start the season fresh with new set of brakes in front and in back, set of best quality spark plugs, had them changes the oils and change the filter of my Kuryakin hypercharger and paid for an over all check then the first day I took it out it started to backfire (never had any problem with it since I purchased it in 2005) then yesterday I could not start it. It's a stage 2 FXSTDI (with power commander) Softail Deuce 2005. First part of the question what went wrong and should it be part of the HD warranty since it was running great before a put it away and since the technicians worked on it it started to backfire and now wont start !? Thanks
Old Apr 21, 2012 | 12:44 PM
tlb's Avatar
tlb
take off the power commander, see if it starts
Old Apr 22, 2012 | 08:26 AM
TickTock's Avatar
TickTock
My friend had an issue like this with his sportster. Turned out to be the battery was bad.
Old Apr 22, 2012 | 01:51 PM
jturn36178's Avatar
jturn36178
My guess ecm (maybe p commander) MAP was corrupted by a bad electical connection. Happens more often than you think. Just takes a reflash of the map. If tha is the prob., then start checking all the electrical connections, battery through the fuses. you don't want that to happen again.
Newfie4Life
Mar 24, 2014 10:02 PM
Aylor70
Sep 4, 2013 09:01 PM
glyates
Apr 6, 2013 10:23 PM
dnitram
Nov 9, 2010 06:56 PM
King FLH
Apr 20, 2009 09:20 AM
