IAC problems?
Old Aug 18, 2018 | 07:16 AM
Ed Ramberger's Avatar
Ed Ramberger
The reason that happens with a bad speed sensor is that the IAC tends to open a little more than it would be at idle when the throttle is open and the bike is in motion. This prevents a stall due to a fast throttle closing event with the bike in motion. When the speed sensor is not sending the proper speed signal, the IAC can be too far closed on a stopping event and the idle will drop or the engine will stall.
Throwing parts like a TP at it is a waste of money and I always cringe when people are telling people to just try this because it's only xxx dollars. The more parts you touch without proper diagnosis, the higher percentage you can actually induce another problem.
Always systematically diagnose and repair. The parts shotgun is a bad thing.
connojo
Sep 15, 2022 10:37 AM
Robottom
Jun 16, 2015 08:56 PM
liverdeluxe
Aug 9, 2013 10:02 PM
carlgrover
EVO
Feb 6, 2011 07:37 AM
Bigbird
Mar 23, 2010 04:18 PM
