HELP I have a charging problem
Old May 23, 2012 | 08:10 PM
artmo's Avatar
artmo
Stage II
Smile HELP I have a charging problem
I have a 96 Heritage softail, I just repalced the original battery, thinking it was just old. Well then I see I have a charging problem. I connected a DVOM to the stator and ran it about 2000rpm and had a reading of 41 to 43 ac output. So I put a new regulator on hoping to fix it. But it didn't. So if you can help me I would appreciate it. Laconia is coming fast. Thanks Art
Old May 23, 2012 | 08:52 PM
slash64's Avatar
slash64
Stage IV
This is exactly the same stator reading 40-46 replaced regulator have checked all connections on my 03 sporty if you find out anything let me know and i'll do the same.
Thanks
Old May 23, 2012 | 09:12 PM
bmchevy's Avatar
bmchevy
6th Gear
Check resistance of stator two pins should be close to 0. Then check resistance of each pin of stator to ground should be infinite. If not replace stator
Old May 23, 2012 | 10:10 PM
slash64's Avatar
slash64
Stage IV
Have already tried that also checks out right?
Old May 24, 2012 | 06:09 PM
Dallas 13's Avatar
Dallas 13
The place to start is with the regulator. 14-15V DC @ 2000 RPM is normal. If you have that, the stator & reg are good. Check all connections, especially grounds at both ends. Even a little oxidation in the connections can block a lot of electricity.
bucksy99
Jul 5, 2016 06:42 PM
hotshot
Jul 19, 2013 09:06 PM
asigetic
Aug 20, 2012 06:56 AM
Bubba97
Electrical/Lighting/Alarm
Jun 19, 2012 08:41 AM
fcast4
Nov 15, 2007 02:24 PM
