'04 Softail Standard Starter Issues??
Old May 30, 2012 | 01:23 PM
mlewis2's Avatar
mlewis2
Stage IV
Default '04 Softail Standard Starter Issues??
I recently purchased an '04 Softail from a Private Seller. The bike runs great, no issues what-so-ever with the exception of a strange noise coming from the starter when the engine is warm.
When I stop after riding (to get gas, rest ect.) and go to start it up, there is a strange grinding / clunking noise coming from the starter. It will always fire up, but the sound is definitely not normal. Anyone had a similar issue? Any ideas?
Thanks
Old May 31, 2012 | 07:46 AM
mlewis2's Avatar
mlewis2
Stage IV
No ideas? I searched around and found a few threads stating it could be starter clutch? any way of verifying this before I tear it apart?
Old May 31, 2012 | 08:23 AM
ajayrk's Avatar
ajayrk
Sounds like the over runing clutch is failing. Part # 36.
http://partsfinder.onlinemicrofiche....ARTER-ASSEMBLY
Old May 31, 2012 | 09:30 AM
mlewis2's Avatar
mlewis2
Stage IV
Can that part be replaced or does the entire starter need to be replaced? Item does not have a price associated with it...Also how hard is it to reach the starter?
Old May 31, 2012 | 11:43 AM
ajayrk's Avatar
ajayrk
That part can be replaced.
You will have to remove the outer primary cover in order to remove the screw that holds the pinion gear on.
Remove the battery from the oil tank.
Remove the two screws inside and near the top of the oil tank.
Remove the nuts from the studs on the rubber isolators and slip the tank to one side to free the tank.
Prop up the tank to allow room to reach the two screws that hold the starter on. You may have to reach through the battery box to remove the battery cable. Remove the small plug from the starter.
If there is and end cover on the starter, it helps to remove it. Remove the screws then wiggle the starter out.
Follow the diagram to remove the clutch assembly.
Starter clutches. http://www.jpcycles.com/search/searc...012814&Ntk=All
J-FRAME
Aug 9, 2014 07:21 PM
supercrewser
Jun 18, 2013 06:56 PM
mlewis2
May 30, 2012 01:20 PM
RoadRich2010
Jan 4, 2012 09:31 PM
hardpill
Aug 26, 2008 09:57 PM
