Noise when starting bike.
Old Nov 17, 2011 | 10:30 AM
RoadRich2010's Avatar
RoadRich2010
Default Noise when starting bike.
I have a 2010 FLHR, every now and then when I start it I have to stop because it makes a terrible noise like something is not engaging properly. Is this something that is normal, I only ask as this is my first Harley...
Ozoneman's Avatar
Ozoneman
Does it sound like this?
http://www.youtube.com/watch?v=p3vOSHPlp00
Have the compensator in your primary checked.
Old Nov 17, 2011 | 10:47 AM
Cooper08's Avatar
Cooper08
The noise you hear is probably the starter clutch grinding. It's not normal and it will get more and more frequent. I think it is the result of another problem-a weak compensator. A lot of people change to the SE compensator because there is not near as much give in the cranking process and therefore easier on the starter. I have not done that yet but I have replaced two starter clutches (the last being made by All ***** that I have not had any trouble with). But I think I'm just fixing the symptom and not the problem.
Old Nov 17, 2011 | 11:36 AM
springer 03's Avatar
springer 03
It is unfortunately normal. It also is the starter drive clutch. It is a known weak component of the starter that Harley refuses to address. I am waiting on a new starter as I type. The sound went from that to that with a gear grinding noise to the starter motor spinning without the starter engaging. The weak compensator supposedly is not helping but the starter should be strong enough to start a directly connected motor without spring loading a crank.
Old Nov 17, 2011 | 02:13 PM
JohnFlorida's Avatar
JohnFlorida
You can get a slap in the primary chain if its too loose
Old Nov 17, 2011 | 05:36 PM
Punjabi Rider's Avatar
Punjabi Rider
Stock compensator is junk sooner or later gona need SE one.
Old Nov 17, 2011 | 05:39 PM
soft 02's Avatar
soft 02
Stock comp kills starter clutches!! Replace both.
Indianspringsaz's Avatar
Indianspringsaz
I am looking at getting the Screamin Beagle compensator soon.
Old Nov 17, 2011 | 07:33 PM
Lowcountry Joe's Avatar
Lowcountry Joe
So you stop it after you start it because of this "terrible noise"? Why? And how do you know "something" is not engaging?
Old Nov 17, 2011 | 08:08 PM
springer 03
So is that the starter clutch banging or the compensator banging?? Does anybody know for sure??
If you are hearing that sound it's only a matter of time before the starter drive is toast.
