HFSM Setup Insructions
Old Jul 20, 2012 | 01:32 PM
jaymiller5's Avatar
jaymiller5
Default HFSM Setup Insructions
For those that would like a quick break down of how to install the hands free security module (no button on the fob) that I just got setup on my Electra Glide Classic today.
---- NOTE ----
The fob activation must be programmed at the dealer this is only to install the HFSM to reduce the cost of the installation.
Ignition switch (on lower dash cap) must be off for at least 15 seconds.
Install TSM/HFSM per the service manual instructions
Set engine stop switch on the right handle bar to RUN
Put the bike in neutral
Turn ignition switch to ignition
Wait for engine and security lights to illuminate and then go out
Attempt normal start one time
Engine should start then stall and engine light should illuminate and stay on
Wait ten seconds then security lamp should illuminate
Wait for security lamp to go out which is 10 minutes
Then turn ignition to off and back to ignition within one second
Security lamp should illuminate and wait for it to go out, another 10 minute wait
Security lamp should illuminate and wait for it to go out, yet another 10 minute wait
Then turn ignition switch off for at least 15 seconds and then turn on, start bike.
You are all set and the bike should start without issue and stay running. Test this a few times to ensure everything is functioning properly.
Hope this helps someone else looking to install the hands free security module.
steelerdude1
Dec 24, 2018 07:34 PM
aklowrider
May 3, 2016 02:36 AM
Vatorman
13
Mar 10, 2011 04:05 PM
Sporty883Low
Jan 18, 2007 11:00 AM
cootertwo
Mar 26, 2006 09:03 PM
