No reading on Spark Plug Cable, Multimeter
Old Aug 9, 2012 | 02:38 PM
brett.'s Avatar
brett.
Default No reading on Spark Plug Cable, Multimeter
hey yall
ive been having some acceleration issues (https://www.hdforums.com/forum/sport...elerating.html) and went to check the spark plug cables today.
3 of 4 of them read between 4 and 4.5 on a multimeter, which seems good to me (my multimeter reads in ranges 200, 2k, 20k... so i put it on 20k). but 1 of the cables didnt read at all, on any range (up to 2M); i only got the OL (overload) code on my meter. it also happens to be the only cable that i believe is over about 18" (its about 24").
could this be causing acceleration problems? would the bike run with only 3 of 4 spark plug firing? i figure it would, just bein sure.
brett.
Old Aug 10, 2012 | 09:54 AM
TorkMan's Avatar
TorkMan
It would run like crap. Set your meter to a smaller scale, like 2k. You should be able to get a read then. If not, go to lowest scale and check for continuity. If you don't see reading there it's Toast. On my flhtc, I have a 19" plug wire and in spec ohms range from 4750 to 11077 ohms. So it would be harder to get accurate reading set to 20k. Some meters will not show anything if you are in the wrong scale. Anyway, good luck!
Old Aug 11, 2012 | 07:52 AM
GraemeR's Avatar
GraemeR
Nah...the 20k setting should be fine to allow you to guage if the wires are toast or working.
Old Aug 12, 2012 | 04:09 PM
brett.'s Avatar
brett.
i tried on every setting, and still no reading. i would up at an HD dealership and they gave me a pretty sweet deal on a whole new set of screamin eagle spark plug cables, so i decided id replace them all. it already sounds better and different, but im still knee deep in acceleration issues and have put new gaskets on the intake manifold...blahblahblah. anyways, i think things improved, but problems arent totally solved. thanks for yalls help regarding the cables.
MacKo2000
16
Nov 8, 2018 12:03 PM
cptseawolf
May 27, 2014 12:38 PM
switzead
Sep 1, 2013 05:59 AM
kwn36
Aug 19, 2013 02:19 PM
spiker
Apr 19, 2010 07:50 PM
