2012 SG LED headlight.
Old Sep 13, 2012 | 09:51 AM
mrchman's Avatar
mrchman
got my regulator swapped fine, and it took awhile but we think we found the issue. the amp rating on the light is less than the bikes light output. theyre looking to aee if harley techs have a resistor part number for me, and if not, I'll go get one myself for it. it is not a plug n play light so far!
Old Sep 13, 2012 | 10:00 AM
UltraNutZ's Avatar
UltraNutZ
I would think a ton of folks would be having this same issue if it were an incompatible amp rating. hmm..
Old Sep 13, 2012 | 10:32 AM
mrchman's Avatar
mrchman
the instructions say there may be a difference. the bike light is sposed to be around 5-6 amps and the like runs between 3 and 3.8 or sonething in that area.
Old Sep 13, 2012 | 10:38 AM
UltraNutZ's Avatar
UltraNutZ
what about your other post where someone mentioned they had the same problem and it was reversed pins on a connector that resolved the issue and that certainly makes sense to me from a technical standpoint.
Old Sep 13, 2012 | 11:43 AM
mrchman's Avatar
mrchman
no pins to reverse, its the same connector as the headlight, plug it in and put in the bucket is all its supposed to be.
Old Sep 13, 2012 | 11:49 AM
UltraNutZ's Avatar
UltraNutZ
i think what he was referring to is the 3 pin connector that plugs into the headlight. the two outside pins were reversed.
Old Sep 13, 2012 | 12:16 PM
mrchman's Avatar
mrchman
thats crazy, but i kinda can see how itd work. ill wait till i get some more info though before i try that.
Old Sep 13, 2012 | 12:20 PM
UltraNutZ's Avatar
UltraNutZ
yeah i agree but you never know.. you two folks might have the only HDs with this issue which I think would make them collector editions :-)
Old Sep 13, 2012 | 12:47 PM
mrchman's Avatar
mrchman
xD interestig thought indeed
Old Sep 13, 2012 | 01:31 PM
02fx4dude's Avatar
02fx4dude
LED using less current(amps) than the stock headlight should not be an issue. In fact it's usually considered better.
LED's are light emitting diodes, I don't think it would work at all if polarity is reversed. correction, they could use diode network to allow operation if polarity at the connector is reversed.
Have you or anyone else measured the voltage to the LED. Some electronics have built in protection for over/under voltage conditions and will shut themselves down. The fact that it shuts down faster when the bike is running makes me suspect this along with the known problems with the 2012 regulators.
Last edited by 02fx4dude; Sep 13, 2012 at 01:51 PM. Reason: correctionfor polarity
