Odometer doesn't work after ThunderMax install
Old Oct 2, 2012 | 09:34 AM
Reindeer's Avatar
Reindeer
Default Odometer doesn't work after ThunderMax install
I just installed a Thundermax w/ Autotune over the weekend (works awesome by the way...) and everything is great, except I lost the display on my speedometer. I have the Harley Speedo/tach combo part #70900070. The display where the odometer, fuel gauge, and gear indicator normally reads just shows 'VIN ER'. I'm assuming that the gauges are confused since the ECM was replaced. Is there something I can do or should have done to pair them together?
Old Oct 2, 2012 | 02:01 PM
t11969p's Avatar
t11969p
Stage I
You have to input the VIN from your bike into the tmax tuner. I believe its in the tuning maps under module configuration/module service data. Make sure you use all caps. Hope that helped. I installed mine a couple weeks ago and am having an issue with the trip odometers returning to actual miles when the ignition is turned off then on. Heard anything on this issue?
Old Oct 2, 2012 | 02:08 PM
golfblues's Avatar
golfblues
This will restore all speedo functions
http://ssdl1.cachefly.net/ThunderMax...I.pdf#view=fit
Old Oct 2, 2012 | 02:47 PM
Reindeer's Avatar
Reindeer
Awesome! Thanks for the help. I'll try that when I get home tonight.
Old Oct 2, 2012 | 03:26 PM
golfblues's Avatar
golfblues
It would be nice if we knew it before everything was tightened & buttoned up. It worked for me but I had to take out the Tmax, plug the original ECU back in, reset with the fuses & reset button, re-install the Tmax. I did have a code "V IN ER" in my speedo display and had no odometer readings which were all fixed with the recalibration. Good Luck!
Old Oct 2, 2012 | 10:40 PM
Reindeer's Avatar
Reindeer
Following the procedure linked above worked. Fortunately on a Dyna accessing the harness connector for the ECM is very easy.
Old Oct 3, 2012 | 08:08 AM
golfblues's Avatar
golfblues
Glad to help
sporty79
Feb 3, 2018 10:14 PM
brad-humble-racing
Apr 26, 2015 09:59 PM
MachU
Jul 27, 2014 11:57 PM
Prw3
Exhaust System Topics
Apr 10, 2013 06:49 PM
ICEMANNN
11
Apr 19, 2007 03:43 PM
