Starter????
Old Nov 24, 2012 | 09:57 AM
Snoman's Avatar
Snoman
5th Gear
Default Starter????
I have an 09 Ultra Classic with 26000 miles on it and intermittently [about every 10-15 times I start it] I get a grinding sound after the initial engagement of the starter & it begins to turn over. This seems to happen more often when the engine is warm....but also does it on a cold start. I am leaning toward the starter begin bad.....but wanted to see if anyone has had or heard of this issue before I spend my time and money on a new starter only to find out that isn't the problem. If it is the starter would you rebuild or just replace?
Old Nov 24, 2012 | 10:02 AM
soft 02's Avatar
soft 02
Starter is fine. Your starter clutch is bad. Remove the starter and replace the starter clutch with an aftermarket unit like an Allballs unit. https://www.google.com/shopping/prod...ed=0CGQQ8wIwBA
Old Nov 24, 2012 | 11:24 AM
Juvi203's Avatar
Juvi203
Stage I
I had the same problem on my 08 Ultra. Did what soft 02 suggested and has not happened since.
Old Nov 24, 2012 | 11:26 AM
soft 02's Avatar
soft 02
Yea replaced the OEM one 3 times before I got the aftermarket one.
Alan7407
13
Mar 18, 2026 07:12 PM
dynamac
Nov 27, 2012 08:36 PM
reddog#1
Sep 16, 2012 07:16 PM
Earnie1200C
Jul 17, 2012 03:55 PM
EasyJoe
Aug 22, 2007 11:06 PM
