speedo/tach combo question
Old Dec 7, 2012 | 10:21 AM
fatboyopen's Avatar
fatboyopen
Stage IV
Default speedo/tach combo question
my speedo is about 20 mph off and increases the faster i go ex- says 55 really doing 80 my tach also idles at 2k the slightest tought to the throtle and it shoots up to 8k it also erases my trip comute every so often what could the problem be ...dirty sensor bad sensor in the crank case any suggestions thanks
Old Dec 7, 2012 | 06:55 PM
mfortkamp's Avatar
mfortkamp
maybe a loose wire or just a faulty unit. the tach is picked up through the crank sensor and the speed is from the trans sensor
Old Dec 9, 2012 | 07:06 AM
UltraNutZ's Avatar
UltraNutZ
pull your speedo sensor from the transmission and clean it up. slap it back in and you'll probably be good to go. if there are a lot of metal shavings on the head sensor you might want to look at the transmission. There is also a connector somewhere close to the battery for this bike. This connector's wires go to the speedo sensor. Follow the wires and you'll find the connector. Pull it apart and make sure it's not corroded. put a dab of dielectric grease in the connector and mate it back together.
NickSchoff
EVO
Sep 19, 2023 11:39 AM
jredd29
Custom Models
May 11, 2011 10:14 PM
GlennB.
Aug 12, 2010 01:30 AM
philinms
May 31, 2007 11:17 PM
emeraldbiker
Aug 14, 2006 10:32 AM
