Starter motor problems
Old Feb 4, 2013 | 12:39 PM
twincaman's Avatar
twincaman
Default Starter motor problems
08 Streetglide, 20,000 miles. For the last few months, when the starter engages, it seems to struggle to turn the engine over. Replaced the battery thinking that was the problem, but it made no difference. Now the problem seems to be worsening. I get a kind of sick feeling that the engine won't turn over, but so far it has.
Old Feb 4, 2013 | 12:52 PM
soft 02's Avatar
soft 02
Check all the connections, check the battery by having it load tested. If all is good clean or replace the solenoid in the starter.
Old Feb 13, 2013 | 11:27 AM
grbrown's Avatar
grbrown
Clean all the hi-power electrical connections, at both ends, as well as the ground. It could be as simple as poor connectivity. If everything checks out OK you may need to strip and clean the starter itself. I did that to mine, some years ago, and was surprised how much dirt there was inside.
ksimo32
Electrical/Lighting/Alarm
Apr 5, 2021 07:51 AM
irydasteelhorse
EVO
Feb 22, 2014 10:00 PM
aces101
Shovelhead
23
Jul 9, 2012 09:02 PM
Mar 26, 2012 06:54 PM
dirty78ironhead
Ironhead
Mar 15, 2009 07:27 AM
