Battery smoke
Old Apr 3, 2013 | 03:27 PM
Hs Fatbob's Avatar
Hs Fatbob
Stage III
Default Battery smoke
Just put my battery back in my 11 Fatbob that was stored in my basement over the long winter. It turned over a couple times real slow then I smelled smoke a low and behold it melted my positve terminal on the battery. I quit there and ordered a new battery, should be here tomorrow.. any Idea what might have caused this to happen? I'm alittle skidish to try the new battery
Old Apr 3, 2013 | 07:15 PM
DJY's Avatar
DJY
loose connection?
Old Apr 3, 2013 | 07:22 PM
Harleycruiser's Avatar
Harleycruiser
Yea a loose connection or corroded connection will restrict the current flow at that point and over load the wire/connection . Think of putting a real small wire in a high amperage drawing circuit.
It will let the smoke out of the wire.
Since the connection on the battery are lead they melt.
Old Apr 3, 2013 | 08:39 PM
Hs Fatbob's Avatar
Hs Fatbob
Stage III
thanks thats entirely possible the connection wasn't tight I'll try the new battery and make sure everything is snug, let you know how it goes
bill from tn
Jan 22, 2023 04:22 PM
jriggle84
Nov 2, 2015 12:15 PM
deadman77
Aug 11, 2013 07:48 PM
fraggerj
Electrical/Lighting/Alarm
Mar 28, 2011 09:31 AM
tr6640
Apr 2, 2008 11:23 AM
