Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Hello. Faced with such a problem with the ignition check engine light comes on, it turns off and after another 3-4 seconds lights up again for 6-8 seconds. Inquisitive to run diagnostics on the scoreboard but the odometer appears d01CLr and so to go further d10CLr foam and then 82,833. Tell me what to do. Experts from Moscow did not answer anything intelligible.
Thank you in advance.
P.S Sorry for bad English/
Hi. I correctly understood from read, what it is necessary to make a wire (in Moscow only to order one month) and to close the first and second contacts and at ignition inclusion the bulb the check will show codes of malfunctions so?
Any piece of wire will do as long as it goes over the pins.
Read the flashes and get the code.
Unfortunately that is about all I can tell you as I find it easier to do that to explain.
