Bad Battery?
Old Feb 18, 2007 | 03:07 PM
USNDiver's Avatar
USNDiver
Default Bad Battery?
Went to start the Springer yesterday for the 1st time in a couple weeks (finally had a nice day) and it cranked once & started clicking. Put it on the battery tender overnight and the LCD was showing green this morning (should indicate a full charge, right?) Tried to fire it up & got the same reaction. Put the tender back on and the LCD went right to "green" after about a minute. The bike's less than a year old but I'm guessing maybe a bad battery. Anyone else experience this or have any thoughts?
Thanks,
Dave
Old Feb 18, 2007 | 03:12 PM
cwsharp's Avatar
cwsharp
Default RE: Bad Battery?
Sounds likea corroded or loose connection...
C#
Old Feb 18, 2007 | 05:30 PM
tmitchellof PG's Avatar
tmitchellof PG
ORIGINAL: cwsharp
C#
I agree. Try taking your battery cables off and cleaning them up. Then recharge the battery.
Tom
Old Feb 19, 2007 | 09:25 AM
cjuetten's Avatar
cjuetten
If that doesn't helpcheck battery voltage afterthe charger indicates its fully charged. If its less than 13 volts it's probably a badcharger.
Old Feb 21, 2007 | 07:33 PM
EVOrider's Avatar
EVOrider
Another thing to check after the battery and cables...is too look at the stud on top of the starter. This area is known for heavy corrosion and dirt which leads to a poor connection. There should be a black rubber cap there. If indeed corroded, disconnect the battery before cleaning that stud...because the stud is hot. It is very likely that it will spark!
Derf_
Apr 20, 2017 06:41 PM
mrodff
Dec 29, 2014 08:41 PM
Gage2502
Jun 2, 2011 06:47 PM
Greasemonkey1
Jul 28, 2010 10:38 PM
davidarg
Jun 16, 2008 10:12 PM
