Side mount brake/tailight
Old May 1, 2013 | 10:03 PM
1911RK's Avatar
1911RK
Default Side mount brake/tailight
Put the DK brake/tailight on my 04 Softail. Every thing was losely mounted, wiring was correct. DK says the housing of the tail light is the ground. Turned the switch, lights on. Grabbed the brake, brake light on. Turned the switch off, tightened all the mounting bolts. Turned the switch on, nothing. Grabbed the brake, nothing. Touched the ground wire from the main harness to the tail light housing and the tail light and brake light work fine.
Anyone have any ideas what might be going on?
Old May 1, 2013 | 11:00 PM
misfitJason's Avatar
misfitJason
So run a ground wire
Damien Bessent
Sep 20, 2022 03:36 PM
Half-Fast Deuce
Sep 23, 2012 07:56 AM
baron310
Electrical/Lighting/Alarm
Oct 18, 2010 08:08 AM
JustDave71
Wheels/Tires
Nov 1, 2009 11:46 PM
cnewty
Jun 23, 2007 01:29 AM
