engine cutting out under accel/load
Old Jun 11, 2013 | 06:49 PM
The-Nomad's Avatar
The-Nomad
Default engine cutting out under accel/load
i have a 91 sportser 883. the problem i am having is the bike cuts out at around 3200 rpm under w.o.t. the higher the gear, the worse the problem. for example 1st gear at 3200 wot coughs minutely then revs all the way to 6000 no problem. 5th gear falls flat on its face at 3200. if i switch gears so it starts off at 4000 rpm there is no problem. im baffled at this point.
things ive done. removed and cleaned carb very thoroughly, new jets, new upper diaphragm, new accelerator pump diaphragm, cleaned pet ****, replaced fuel line. i made adjustments to the air fuel. i moved the needle up and down every clip. nothing makes any difference. im at a total loss here. please help.
Old Jun 11, 2013 | 06:51 PM
rooti's Avatar
rooti
what other engine mods? What size jets are you using?
Old Jun 11, 2013 | 08:36 PM
The-Nomad's Avatar
The-Nomad
drag pipes
k n air filter
180 main jet
048 slow jet
had a dynojet thunderslide kit installed but put a stock slide back in with new diaphragm. kept the spring and needle from the kit tho. needle set on the 5th notch down.
Old Jun 11, 2013 | 08:39 PM
Dangermouse's Avatar
Dangermouse
Check your plugs, I had one were the ceramic broke loose around the electrode. It would slide down and block the spark path making it miss intermittently.
Old Jun 12, 2013 | 07:49 AM
The-Nomad's Avatar
The-Nomad
i put new plugs in when this started
Old Jun 12, 2013 | 09:57 AM
Assegai's Avatar
Assegai
Airleak on the intake?
Old Jun 13, 2013 | 07:36 AM
The-Nomad's Avatar
The-Nomad
i put brand new seals on this week. nothing changed.
Old Jun 13, 2013 | 07:38 AM
The-Nomad's Avatar
The-Nomad
could it be a timing issue? if so, how do i check timing. and what controls the timing advance?
Old Jun 13, 2013 | 05:53 PM
The-Nomad's Avatar
The-Nomad
put on a brand new coil and plug wires today... still having issue... no better no worse
evansmoe
Engine Mechanical Topics
14
Jun 8, 2014 01:17 PM
The-Nomad
Exhaust System Topics
11
May 11, 2013 05:06 AM
The-Nomad
Carburetor Related
May 2, 2013 06:21 PM
Knights2TheEnd
Oct 14, 2012 10:16 PM
ngf74
Ironhead
Oct 21, 2006 06:59 PM
