Starting up problem. HELP eelcome
I searched all of the forum and in the internet for this problem and could"t find any real answer.
I have a 2009 Crossbones with Vance and Hines Short Shots (with quiet baffles and smartpartz baffles, RSD open air filter, no mapping (yet!) and having troubles starting up my bike since 4 weeks. The problem is intermittent (one every ten times or so). The bikes cranks normally but doesn't come to fire up. After it cranks, the ignition loads automatically. I sometimes have to try 6 times before it goes. What I recently notice, is that using the throttle while it cranks helps to fire it up.
Could it come from the battery (it looks OK to me and it is plugged on a tender most of the time)? The mapping? Pipes?
If you have any suggestions, I'll appreciate any help!
Thanks
Lucospock
