Help please with weird starting problem
Old Sep 8, 2013 | 06:28 AM
lucospock's Avatar
lucospock
Default Help please with weird starting problem
Hi,
I have posted my problem on "electrical/ignition" forum with no luck. So here I am again...
I have a 2009 Crossbones with Vance and Hines Short Shots (with quiet baffles and smartpartz baffles, RSD air filter, and having troubles starting up my bike since 4 weeks. The problem is intermittent (one every ten times or so). The bikes cranks normally but doesn't come to fire up. After it cranks without starting, the ignition pump loads automatically again. What I recently notice, is that using the throttle while it cranks helps to fire it up.
I went back with stock pipes and stock air cleaner but the problem persists.
If you have any suggestions, I'll appreciate any help!
Thanks
Lucospock
Old Sep 8, 2013 | 06:46 AM
1harleyman's Avatar
1harleyman
does it start hard when the engine is hot, or does it not make a difference, if it only does it when its hot , might be your coil going bad
Old Sep 9, 2013 | 02:19 AM
lucospock's Avatar
lucospock
Thanks for your answer.
I have had trouble with my previous nightrain starting while hot.
With this bike, the crossbones, it's when she's cold. In the morning or when I start her up in the afternoon after she sits for a whole day....
Old Sep 9, 2013 | 04:53 AM
Tracker56's Avatar
Tracker56
Is it showing any codes? It might be your throttle position sensor out of adjustment or your temperature sensor...
Old Sep 9, 2013 | 07:28 AM
Rodzilla6's Avatar
Rodzilla6
I don't think this is your problem, but a common one is the starter relay...it is in the fuse box, it's small and only costs 5 bucks...mine failed twice which is a pain, so I keep a spare in my tool kit. Mine started to go on when you were already going...not good. Hope it works out.
Old Sep 9, 2013 | 07:57 AM
lucospock's Avatar
lucospock
No codes are showing!
Tracker56, you may be right. If it's the throttle position sensor or temperature sensor, are there any risk of damaging the engine? Any risk of having complete breakdown?...I would hate calling for a tow truck...
Thanks! I really appreciate your help
Mucster
Carburetor Related
Aug 26, 2018 06:20 PM
lucospock
Aug 21, 2013 02:27 AM
HD Bob
Flathead
Jul 7, 2013 06:08 PM
Treyben
Oct 17, 2012 09:11 PM
wharfcreek
Exhaust System Topics
Aug 2, 2007 09:06 AM
