Battery Mishap Help
Old Sep 22, 2013 | 12:09 PM
charlie812's Avatar
charlie812
Stage II
Default Battery Mishap Help
So this sounds nuts but it happened. I have a late model sportster, 2011, i was taking out the battery yesterday. while taking out, the battery is free. i look behind me for something, and moving back a wrench slides off the seat lands directly on top of both terminals and pinches the ground wire on the terminal too. So i now have sparks flying, wrench, and ground cable stuck to the battery, after many burns i get all off. So deep breath. test the battery, meter still has a 12.7 on it. i reconnect to the bike after i do what i'm doing. turn key to ignition. turn on pump, hit go and the bike shuts off. so i figure battery needs a charging. charge it, put it back in. turn to ACC speedo and plate lights go on. turn to IGN nothing everything dark. turn back to ACC same lights go on. if i press the horn everything goes dark. All fuses are good. any thoughts other than replacing the battery? could i have fried something with the ground still connected and then wrench completing the circuit. The positive wires never made contact with the bike during my little mishap.
Old Sep 22, 2013 | 12:56 PM
cfreeze's Avatar
cfreeze
check your fuses, may have popped the ecm fuse.
Old Sep 22, 2013 | 04:41 PM
Assegai's Avatar
Assegai
12.7 indicates a dead battery.
Old Sep 22, 2013 | 04:49 PM
Juan L's Avatar
Juan L
Moderator
Dead battery. What you did was discharge the battery very very quickly which may, or has damaged the cells internally. Did the amperage flowing through your wrench do any welding? You can try charging overnight but it may not come back.
Old Sep 23, 2013 | 11:05 AM
charlie812's Avatar
charlie812
Stage II
got it all sorted. battery charged over night. fired up this morning. just need to test the battery to see if it's still good. thanks for the help.
Old Sep 23, 2013 | 11:07 AM
nhrider1's Avatar
nhrider1
It sounds like the battery is shorted internally as a result of the mishap. It's not handling even a small load. I'd replace the battery.
sfad
May 4, 2014 10:36 AM
mja52403
Jun 29, 2013 11:12 PM
Sandy Mike
Mar 15, 2012 08:23 PM
Rainmakr
Mar 10, 2012 12:40 AM
twhill3
Dec 11, 2010 12:17 PM
