Fuel pump issues
Old Oct 1, 2013 | 01:43 AM
King Hit's Avatar
King Hit
Stage II
Default Fuel pump issues
Hi Guys.
Im hoping someone can help or at least confirm what I believe to be the problem.
I have a 2001 Heritage Springer. It was running sweet till the other day when I went to start her.
Turn key switch all good
hitrun switch... no fuel pump whirrrrr ????
hit start button she ran for a second then died and wont start again.
but if I let it sit for half an hour, she will do the exact same thing again.
I checked the fuses, all fine then I replaced both relays.
Now when I hit the run button there is still no whirring sound from the pump but I can hear the relays tick in time .
I believe its the fuel pump itself that's died, would I be correct or is it something else ??? hope some one can help because im about to sell this bike and I don't want it causing dramas for its new owner..
Old Oct 1, 2013 | 11:07 AM
Mr. Wizard's Avatar
Mr. Wizard
Originally Posted by King Hit
Hi Guys.
With the info you gave you seem to be correct but remember... If the fuel system is pressurized the fuel pump will not ramp up when you hit the run switch. Do you have any way to check the fuel pressure? That would tell you pretty quick if the pump is working or not.
Old Jun 8, 2022 | 09:22 AM
TheNeonGuy's Avatar
TheNeonGuy
What?! No replies to this post? I see more and more of this problem, but there seems to be little help or info on it here...
HELP!
Old Jun 8, 2022 | 09:41 AM
eighteight's Avatar
eighteight
Deleted.
I see you have a different post open
Old Apr 21, 2023 | 11:43 AM
korey's Avatar
korey
What.was the end game?
Old Apr 22, 2023 | 09:55 PM
greg3131's Avatar
greg3131
Hi Guys.
I believe ithe fuel pump itself that's died, would I be correct or is it something else ??? hope some one can help because im about to sell this bike and I don't want it causing dramas for its new owner..
Fuel pumps don’t last forever , also the fuel lines inside the tank don’t last forever .
Replace EVERYTHING inside the tank . Just my uneducated opinion .
Greg 07 FXDB
AMB2710
Oct 11, 2021 10:45 AM
YellowHawk
Feb 18, 2013 07:25 PM
ironcrab
Nov 11, 2012 05:51 PM
DavidStiebel
Sep 7, 2012 11:51 AM
live2ride777
Mar 9, 2010 05:53 PM
