Tail lights not working
Old Jan 5, 2014 | 04:33 PM
Alan Waters's Avatar
Alan Waters
Stage I
Default Tail lights not working
I replaced all the lenses on the back of my ultra classic to smoke lenses and when put everything back together they didn't work. All other lights work
Old Jan 5, 2014 | 04:45 PM
flicksport1200's Avatar
flicksport1200
SOUNDS LIKE A GROUND, not knowing what all you took apart, i know when i relocated my front and raer light on my 05 fxst everything work except my front left turn signal and spent two days taking it apart and putting it back together to find out from my brother that my left rear light was grounding out, fixed that and all was well again
Old Jan 6, 2014 | 08:49 AM
grbrown's Avatar
grbrown
Hi Alan and welcome to HDF from the UK. We get a steady trickle of new members who have done work on their bike and found it doesn't work! I suggest you carefully go over everything you've done and check that the wiring is still sound and connectors properly connected. Each of the rear lights connects into the central fender light unit, where the wiring goes forward into the main harness. You may have a false ground under the fender.
09IronRider
Milwaukee Eight (M8)
Dec 27, 2018 12:34 PM
wjg
May 30, 2017 07:22 AM
Kpjohns75
Electrical/Lighting/Alarm
Aug 4, 2016 05:56 PM
pupuslinger
Jul 21, 2014 08:16 PM
joe mayo
Mar 3, 2014 07:55 PM
