PCV or SESPT for 2013 Street Bob
Old Mar 14, 2014 | 08:34 PM
jmerchant.1's Avatar
jmerchant.1
Default PCV or SESPT for 2013 Street Bob
I am purchasing a 2013 street bob in a couple weeks. The only upgrade it has installed are Vance & Hines short shot pipes. Everything else is stock. I'm looking to buy a tuner and have been researching options--I've narrowed it down to either the Power Commander V or the Screamin' Eagle Street Performance Tuner.
Basically I'm looking for which ever one is more user-friendly, easy to self-install, and suitable for my bike/setup. (Eventually I would like to modify the air filter system to complete the stage 1 upgrade which is also a factor to consider).
Which should I go with? Opinions? Thanks in advance for any input!
Old Mar 15, 2014 | 01:02 AM
wurk_truk's Avatar
wurk_truk
You simply do not want a power commander on a 13 bike. TTS, SEPST, or Power Vision will be your three choices
Old Mar 15, 2014 | 05:00 AM
Oz Nightrain's Avatar
Oz Nightrain
Listen to wurk truk. He knows his s**t!!
Old Mar 15, 2014 | 08:29 AM
jmerchant.1
What is wrong with power commander?
Also I've heard more bad than good about V&H Fuelpak but if all I ever plan to do is a stage 1 is it still a bad option? I have no interest in getting into motor/cam changes or anything like that. I just mention Fuelpak because it looks to be the simplest tuner to install and use for a stage 1. Yes? No?
Old Mar 15, 2014 | 09:07 AM
Yardstick's Avatar
Yardstick
Power commander is an add on and may result in problems. I used one on a 2011 SG and everything was great for a short time then lots of problems.
Powervision is made by the same company; however, it is a flash tuner that will take any map loaded into the ECM and you can do data runs to fine tune it for your specific bike. That will result in a much better running MC.
SEPro does the same thing.
PV is a little easier to use.
harleylay
May 5, 2019 02:18 PM
jmerchant.1
Exhaust System Topics
Mar 9, 2014 05:38 PM
TheBlackWolf
Aug 9, 2012 06:03 PM
D.Bob
Mar 28, 2012 03:25 PM
wellsey
Jan 22, 2011 07:36 PM
