engine vibration
Old Mar 25, 2007 | 01:04 PM
hdfatboy54's Avatar
hdfatboy54
Default engine vibration
I have a 2002 fatboy TC 88 with a few mods, vance & hines exhaust and carb rejetting some time back,None to the engine. I haven't noticed it before but I seem to have a fine vibration at around 70mph and up. It is either engine or primary chain, I think. When I am getting this vib I can pull in the clutch and roll off the throttle and there is no vibration, so I know it's not the tires. I have 31k miles on this bike and have keep it serviced very well all except the serious stuff, like cam chains and such. Any Ideas what to look for or do ya think this is normal.
Old Mar 25, 2007 | 11:24 PM
Retired_Ted's Avatar
Retired_Ted
Default RE: engine vibration
With that many miles, I'd start thinking about cam chain tensioners or bearings. Almost has to be in the engine or primary from what you describe.
Old Mar 26, 2007 | 10:56 PM
hdfatboy54's Avatar
hdfatboy54
replaced the outer chain tentioner at 30k. it bearly had some wear, so i didn't go on back to the inside tentioner. I have always run amsoil 20/50 synthetic. So because of the little to no wear I thought maybe the chains would be good. But if you think it could be this then I will go deeper. And by the way, Thanks TED for the reply I also thought of replacing the cam chain wit the gear to gear type cams, any thoughts on this change?
Old Mar 26, 2007 | 11:02 PM
Retired_Ted
Almost has to be engine - primary area related - have your dealer ride it and see what he thinks. Most likely, another bike's been in for the same thing if the shop foreman has experience. Good luck, my friend.
Bart van der Meulen
Mar 9, 2017 07:03 AM
gvoxx
2014-2024 Touring Models
11
Mar 11, 2015 06:48 PM
zeus33
Jan 3, 2015 09:58 AM
rpbrown
Oct 4, 2013 07:13 PM
njesus
Exhaust System Topics
May 19, 2008 10:53 AM
