Ecm
Old Jun 3, 2014 | 03:04 PM
JimGnitecki's Avatar
JimGnitecki
Originally Posted by db133
Re: HD chrome they used it under black paint on my rack ! Strange but true.
Re: Ecm I have a power commander connected. I was wondering what would happen to my Dyno tune map. Collected the bike (Ł500 ! ouch) nice ride home, time will tell.
Thanks for your input fascinating subject, any one have a picture of inside the ECM ?
Kind regards to all. db
A Power Commander map simply MODIFIES the signal that the ECM is sending to the fuel injectors, either adding more, or subtracting, fuel compared to what the ECM intended. If the ECM fails, it should not normally break the Power Commander. Likewise, a Power Commander failure should not normally cause the ECM any harm. However, if there is a catastrophic event like a voltage spike, it could kill both.
The power paint on the luggage rack over top of the chrome was likely simply the HD factory running short of black luggage racks that production day, but having plenty of chrome ones, and making the tactical decision to coat the chrome ones with black powder and us them on the "black" bikes.
Jim G
Old Jun 4, 2014 | 02:40 PM
db133's Avatar
db133
6th Gear
that all makes sense to me J.
So now the Q ....whats the best way to stop "catastrophic event like a voltage spike" ?
off topic ... how long does a battery last 4 or 6 years ? allways kept on trickle charge .
Regrds
Old Jun 4, 2014 | 03:16 PM
JimGnitecki
Regrds
Catastorphic events are too rare to be worried about (e.g. an alternator short or regulator failure).
I think a Harley is a tough environment for a battery: high current draw to start a big twin, lots of vibration compared to a car, etc. I wouldn't plan on more than 3 years unless you use a SMART (not regular) trickle charger, AND you are very lucky.
Some of the bad things about continuing to use a weak battery are:
- It will leave you stranded at the worst possible time
- It will irritate you a lot before it finally fails (mysterious electrical and engine performance shortcomings)
- It can cause the contacts on the starter relay to overheat, melt into each other, and then run the starter, even after you release the starter button, until the battery, or starter, or both get ruined.
Running a weak battery makes no sense. New ones are not that expensive.
Jim G
Veritas01
Jul 4, 2019 04:07 PM
merdahl
14
Oct 23, 2011 10:04 AM
TexasVet
Apr 20, 2011 01:20 PM
AK_Hog_Herder
Jun 16, 2006 11:48 PM
HDF Tech
Electrical/Lighting/Alarm
Jun 28, 2005 12:25 PM
