Ecm
Much as we love my 2006 FXSTBi (!)
I need to understand what is inside the ECM.
My one is in the local dealership being replaced :-( any one opened one up ?
Are they programed to expire ? Is it a common problem ?
Is it time to strip it all out and get back to basics ?
You all take Care. db (UK)
- Exposure to a magnet MAY hurt or kill it, especially if the bike is running at the time. On a practical basis, the most likely way for this to happen is for someone to add a magnet that triggers traffic light left turns signals when the bike itself won't reliably do so., but this is only if the magnet and the ECM are in pretty close proximity. COULD happen on a Breakout or Rocker, where the ECM is buried just in front of the rear wheel.
- A voltage spike delivered by a defect in the electrical system can kill it.
- Water exposure can kill it, and even if it doesn't it will start corrosion that will likely kill it given some time, but will be preceded usually by erratic operation before final death.
- Water IMMERSION (e.g. bike tipped over into water puddle) will almost certainly kill it.
- Long-term exposure to high humidity, like you find in many parts of the UK where you are located, can cause corrosion on the terminals, even "inside" the connectors, that will likely manifest first as erratic or improper operation, and end in inability of the bike to run. This is why dielectric grease is used on electrical connections in vehicles. It provides a barrier against water or humid air entry.
- Physical pressure onto the ECM can impair it or kill it. (Example: Rider installs a seat not intended for this model bike that puts pressure directly onto the ECM)
- Battery leak onto the ECM can impair and then kill it.
Looking at your UK location, I'd look to terminal corrosion first maybe.
Jim G
Just normal use as per the last 7/8 years and stored in the dry when not in use.
Chap at the dealership said he is getting quite a few that require replacement.
So what is inside it then ?
Kind regards.
- Circuit boards
-Electronic devices on the circuit boards
- Connections between the devices
- Connector terminals that allow the ECM to communicate, both directions as needed, with physical and electronic components spread throughout the bike.
Jim G
There is for the most part, very small amount of read only stuff, most can be adjusted, just not by the tuners available today. The Delphi calibrator tool can get to most areas.
So that makes me think that dealer is full of **** and is possibly ripping folks off.... either on purpose or from incompetence. ECMs going 'bad' is a truly non issue.
What is the reason YOUR ECM went 'bad"?, If you know. Very curious.
Re: Ecm I have a power commander connected. I was wondering what would happen to my Dyno tune map. Collected the bike (Ł500 ! ouch) nice ride home, time will tell.
Thanks for your input fascinating subject, any one have a picture of inside the ECM ?
Kind regards to all. db
