Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I'm going to be installing a set of SE-255s in my 09 Street Glide (96") that is currently equipped with Rinehart 3.5 True Duals, Arlen Ness Big Sucker, and PCV. I don't have anywhere close by to get a dyno tune, therefore I am looking for a map for my PC-V. Does anybody have one that they wouldn't mind sharing. Thanks.
Heres what I found
MAP# 15-011-252 your build with 4" rineharts
MAP# 15-011-233 w/fuel moto jackpot slip ons and quiet baffle
MAP# 15-011-138 103 build rineharts and 255 cams
I spoke with Dynojet yesterday and he said theres no set map for every motor/cam/pipe combo. They take a 96 and 103's with and without cams and install pipes and dyno them. They change a bunch of pipes on the same motors and record a map.
They also said all 2:1's will be the richest maps, the true duals leaner and slip ons will be the leanest tunes. Food for thought. Hope this helps
