Ironhead A place to talk about Ironheads.
Speedo 2240:60?
Old Apr 13, 2018 | 11:54 AM
Spurlee's Avatar
Spurlee
Default Speedo 2240:60?
I'm bringing a 1981 XL back to life. It has an aftermarket Fat Bob style tank with a dashboard mounted, HD OEM speedometer that is wrecked and I want to replace.
There are no markings on the speedometer to identify the type (1:1, 2:1, 2240:60). When I replaced the front wheel mounted speedometer cable I counted the revolutions it makes at one full turn of the OEM 19" wheel.
The cable turns more than twice for each revolution of the wheel - about 2.3:1 would be my estimate. Is that what a 2240:60 drive does?
Why does this oddball drive even exist?
Thanks!
Old Apr 13, 2018 | 03:01 PM
yellowstone kelly's Avatar
yellowstone kelly
I can tell you that all ironhead sportsters (whether tranny driven or front wheel driven) came from the factory with 2:1 speedometers.
On my '82, my stock speedometer says I'm going about 10% faster than I really am, and my odometer shows I've traveled about 10% farther than I really have. I had to replace my speedo once, and the stock replacement speedo was exactly the same as the original. So 2:1 isn't very accurate, IMHO.
On a 2:1 speedo, "2000 rpm of the cable equals 60 mph" on the speedo dial. On the 2240:60 speedos, it's "2240 cable rpm equals 60 mph" on the dial.
This is mostly a guess on my part, but it seems to me they're trying to improve the accuracy with the newer 2240:60 speedo, since 2240 is just a little bit more than 10% of 2000.
Old Apr 13, 2018 | 07:18 PM
Spurlee's Avatar
Spurlee
Thanks for the help! It certainly makes sense, explaining the 2:1 nomenclature brought it all together, although why it isn't termed 2000:60 is beyond me.
There aren't as many style selections in the 2240:60 style. You have to really want one I guess.
I bought one this afternoon and will be matching it to the drive that came with the bike. I'm sure it will be fine.
Thanks again!
Old Apr 13, 2018 | 08:15 PM
IronMick's Avatar
IronMick
I have never looked into these different speedometer ratios, so I personally have no clue as what ratio to look for, or even what the ratios mean. I would trust everything that yellowstone kelly had to say because I have known him on these forums for many years.
What I have done is, when needed, replaced with a used or aftermarket Harley Davidson model and not even given a thought to those reference numbers. And quite frankly I do not give a Tinkers D@mn if it is 10% or whatever % off
Old Apr 13, 2018 | 08:43 PM
TexasScooterTrash's Avatar
TexasScooterTrash
If my memory serves me correct, the 2240:60 was used in the early mid 90's with the reed switch to cancel the turn signals. Late 90's HD changed to the electronic speedo & turn signals. You will need a Big Twn speedo with a 2:1 ratio.
Old Apr 14, 2018 | 07:33 AM
Spurlee's Avatar
Spurlee
Texas, Reed switch...more research needed I guess. There's turn signals and they work but who knows how or if they self cancel at all.
Iron Mick, This is the same bike you advised me on a few weeks ago...New topic.
Old Apr 14, 2018 | 02:12 PM
IronMick's Avatar
IronMick
No IronHeads came with self cancelling turn signals - unless you mean "cancel them yourself"
Old Apr 14, 2018 | 08:53 PM
TexasScooterTrash
Mick, this is an AFTERMARKET FAT BOB conversion tank with BIG TWIN speedo. Looks like you missed this little detail. LOL
Old Apr 14, 2018 | 08:55 PM
TexasScooterTrash
Spurlee, take a photo of the speedo - face and back side. Let's see if it can be identified. There are still Fat Bob tank conversions out there by different manufactures. Some use 2:1, some use 2240:60.
Old Apr 15, 2018 | 05:59 AM
Spurlee's Avatar
Spurlee
I guess I should have taken a picture right away, no? I'll grab one this afternoon when I'm at the shop.
