clutch issues
i think i read in a book(dont laugh) that the rouigh edges on the steel plates were common and are just suppose to face outwards.you think its best to file the edges off the steel plates?
H-mmm, I guess I never read that book. Most clutch plates with some miles on them may be burred. If the burrs get really bad they can cause the plates to not move freely. File the burrs if it makes you feel better. (I have never filed mine, if that tells you anything) The best remedy for badly burred plates is a set of new plates.
got my 81 about a month ago..alot of learnin some ridin...no regrets.anyway the clutch was slippin bad wheni got it.adjusted it.pulls good requires a little force to get into 1st..all other gears shift fine.its very hard to start while in gear.i tightened it up more than it should and i still have that problem.i am about to replace the clutch friction/steel plates..springs and any thing else i can think of.------what else can i check..what would cause this problem?is it a trans problem?
If it is a 1981, it is too new a machine for me to comment on regarding the clutch, or the adjustment thereof.
However, the shifting I can comment on.
Yes, it will require much more force required to get it into 1st gear, than it will to shift it to the other 3. The reason is this: The engine is running in neutral. You pull in the clutch and press the lever down into first. You are going to the lowest gear, which has the greatest difference of ratio for the engine rpms versus the rear wheel rpms (which are zero because you have not started rolling yet. It goes into 1st gear with a loud clunk! Maybe the bike jumps forward a bit as well? This is quite normal.
But let me ask you this...... when you shift to first with the engine not running, does it go into gear easier? (You may have to rock the bike forward and backward to get it to engage) Does it clunk? No, it simply clicks.
The hard to put into gear is simply a combination of the engine running, the rear wheel not turning, and a normal amount of natural clutch drag. When you are rolling, shifting into 2nd, 3rd, and 4th is click-click-click. Reason for that is mainly because the bike is rolling and you have syncromesh transmission. All of the above is normal and is not a sign of problems.
To be truthful, you can be in 2nd gear running down the road with foot pressure applied to the shift lever and suddenly back off the throttle quickly. The bike will shift to 3rd (or 3rd to 4th) without pulling in the clutch faster than you can bat an eye. I do not recommend doing this for 1st to 2nd because of the lower gear ratios, but to 3rd on up is fine.
In summation, I say you have no transmission problems related to the shifting issue. If you had bent shift forks (and that can happen) then it will not shift to any gear easily.....and yours does.
Another tidbit of info: The bike is not meant to be started in gear. Most of the Sporties that have electric start also have a neutral lock out switch to prevent you from using this practice. Again, because of the natural clutch drag, being in gear causes friction and the starter does not want to spin. Start the bike only in neutral.
There is a specific procedure to adjust your clutch cable. Read the instructions and follow them to a tee. It sounds like by 'you have tightened it more than required' that you have adjusted it incorrectly already. Read the book........pg
the burr issue --i beleive i read that in a book written by zimmerman but i forget name of book.
yep..not running it shifts fine.running only is 1st "jumpy".why is this ok though.in a car it would not be ok...same basic concept....?clutched in(hand lever pulled in) it will still want to go forward.i only tightened over the amount than specified to see if i could get rid of the pull but could not.i then adjusted back out.------understand what youre saying about not using the clutch..just getting off the throttle.like on a big truck.believe me i totally respect what youre saying but going into first is really bad.on everything else ive ever driven...autos..trucks..tractors very old to newer stuff...it sounds/feels bad.it seems though sometimes its worse than other times.
i will go back and adjust it again and see what happens.
Yeah, I hear you regarding the horrible clunk 'n jump with first gear. For the most part though, that is what it is with an ironhead.
What is causing this to be extra bad with yours (and also with many ironheads, mine included) is caused by the clutch dragging and the rather heavy oil used in a Sportster.
Let me say right here that I am talking about a 1974 or older machine.
Yours is a 1981 and I know you use an oil lighter than 60wt. I do not know what improvements have been made since 1974, so that is why I cannot help you on getting yours adjusted.
On mine, which is a right hand shift, there are 3 steel ball bearings sitting in a cup inside the primary case. These bearings and the cup have a ramp and the clutch cable is connected to the ramp. You must adjust this ramp correctly before youcan adjust the cable slack. It is a procedure that you have to follow to get it correct. I am sure your 1981 clutch is very similar, but I am not familar with the details. So you will have to follow the book.
I can tell you that a Sportster will never even remotely resemble a Honda, Yamaha or any other brand X machine when it comes to shifting into first gear at a standing start.
I also have a 2003 Dyna LowRider. If I kill it at a red light, all I have to do is pull in the clutch and hit the start button and if fires right up while in first gear. A Sportster (old one) will not do that. In fact, as I have said before, some Sportsters had a neutral lock out switch installed to prevent you from starting them in gear. Or trying to start them I should say. These things are meant to be started in neutral and that is just the way it is.
Oh, let me add that my 2003 Dyna also has the loud clunk! when it goes onto first also. That's just the Harley way.........pg
In those years I used 70wt Castrol in both the engine, primary and transmission. On an old one like mine the oils mix so you need to use the same type everywhere. Yours is different.
Anyway, back when I had the 70wt oil in it and it was winter time, you had better not be standing in front of me when I put it into first gear! I mean the whole bike would just launch itself down the driveway. The heavy cold oil was just sticking the plates together and the clutch was locked up. Normal for a Sportster. After the engine warmed up it was much better and then the bike just clunked and jumped a little when put into first gear.
The Harley dealers started stocking Harley 60wt oil several years back and I was happy to see that! That is what I use now. Back in 1971 the recommended oils were Harley (of course):
#105 for extreme service in hot weather. This was approx equal to 70wt.
Normal service called for #75. This was approx equal to 60wt.
Cold weather (40°F and below) required #58. This was equal to 50wt oil.
All of those old designations were Harley's and were not an S.A.E. rating as other oils used. I guess this sold a lot of oil for Harley back then.
When you put your transmission into first gear you have a number of gears inside spinning around because of some clutch drag but mainly due to the oil making the gears spin with the clutch shaft which is turning. The clunk sound and the jump comes from two gears engaging suddenly when one or more gears are spinning around in there. The engaging gear has dogs on the side of it that engage into the side of the spinning gear. The shift forks and the cam gear move the gear sideways when you push the shift lever.
I do not think you have transmission problems at all. I think you clutch is fine also. It may need some adjustment, so read the instructions and adjust it by the book. Then you will know all is well. Just ride it and enjoy having a Harley Davidson Sportster.
Longest made model Harley has ever manufactured. The first one was in 1957 and they have been made every day of every year since then for the past 51 years now. There has never been another motorcycle made that can make that claim..........pg
Some guys just grab the clutch cable adjustment barrel and take out the slack. Failing to do the adjustment you mention first then will cause them big problems and they then wonder why the clutch slips..........pg
