oil migration question
A couple of questions here:
With your rework of the engine, did you remove the oil pump or any of the gearing connected to drive the pump?
If so, did you properly retime the rotary breather valve?
It sounds to me like this may be the problem.
The rotary breather valve is the round turret at the top of the oil pump with the spiral gear that is driven by the oil pump drive spiral gear, located behind the pinion gear on the crankshaft.
The rotary breather valve needs to be timed to open as the pistons come down. This allows the scavenge oil to be moved from the crankcase breather oil trap into the timing cover. The oil is then scattered around throughout the timing cover lubricating the generator drive, the gears, etc.
The air pressure that was created from the pistons coming down is expelled through the tube located below the generator. Only air comes out because an oil slinger on the generator end separates the oil which keeps it inside the timing cover.
When the pistons go up, the breather valve closes and this creates a vacumn inside the crankcase. The oil in the timing cover falls to the bottom brass screen and flows into the bottom of the oil pump where it is pumped back to the tank.
That is how the system works.
What makes me suspect that your breather valve timing is not correct is the excess oil being pumped into the primary area. If the breather valve is not timed correctly, then the pressure from the pistons coming down acts as a huge pump and the oil has to go somewhere. The breather valve is closed (due to improper timing) so the oil cannot be transferred to the timing cover. So, the oil gets pumped through the breather screen on the primary side, where it just sits and accumulates inside the primary. And, oil does not get returned to the oil tank properly.
This is the only thing I can think of that could cause your primary to load up with engine oil. I would not run the bike until you get this sorted out.
If you need any direction with timing the breather just let me know.........pg
[IMG]local://upfiles/8331/ED94BDC50C6846FF972DB334D27BADD6.jpg[/IMG]
'I have good exhaust coming from the breather tube. If the breather were out of time would I still be getting this?'
If the breather was out of time you would still be getting a strong flow of air out of the tube because the pistons coming down make this pressure flow out of the open tube, regardless of where the breather is positioned. In otherwords, the breather still is rotating and letting air escape through the open tube.
The timing of the breather is important because it must open when the pistons come down and close when the piston go back up. This is what moves the oil from the breather trap into the timing cover. If this is out of time, then the oil does not move out.
Did you do the timing yourself on the breather?
Or did someone else do it? If that is the case, how much do you trust the person who did it?
To check the timing it means that you must loosen up the pushrods, remove the timing cover and remove the pinion gear. If you have done this yourself before, then you know that a special remover/installer tool is required and that the thread in the end of the crankshaft is 5/16-24 (fine) and is a left hand thread. (I made my own back when I rebuilt my engine and have attached a photo below for others who may need to make one.)
After the pinion is removed, there is a spiral gear behind it that is a slide fit on the shaft. There should be a mark on one side of the gear. That side faces out toward the pinion gear.
This spiral gear (as well as the pinion gear) can only be installed in one position due to the single large spline on the crank.
Push the spiral gear onto the shaft, engaging the breather sleeve gear to where the hole in the breather valve will be centered in the slot on the breather sleeve bushing. Then reinstall the cams.
I am sure you know all of this, so forgive me for the repeat of the procedure. I am just trying to explain it in a way others who do not know how this is done will be able to follow this thread.
If your timing is indeed correct, then I am stumped. If you did the timing and trust yourself, then that is good. If someone else did the work, I would go in there and make certain it was done. A pain in the butt I know, but I can think of nothing else that would cause the problem you are having. Keep us posted.....pg
[IMG]local://upfiles/8331/8549E78D23F947BEA215385E74F92683.jpg[/IMG]
I was afraid of the breather tube answer. I did put the breather in myself. [:@]Ichecked the cam lobes replaced a washer or two and checked the end tolerances. They were good and cams in time. Engine was on the bench with primary parts off, trans out and top end off.So I remember the oil pump has to go in with the cam cover off. I Left everything in place, ran the crank around to the advance mark and slipped the breather in so the timing dot was facing out and finished off theoil pump installation.Do I trust myself? Hell no. I willbite the bullet andthe cam cover comes off this weekend.Thanks.
Good that you do not trust yourself. I do not trust myself either.
When you install the spiral gear onto the shaft and engage it with the breather gear, it is similar to installing a distrubutor in a car engine. You have to 'over compensate a bit' to get the hole in the breather to register in the middle of the slot in the bushing when the gear is sitting home against the crank face. That is because of the spiral movement.
Before you take anything apart:
Put the timing mark dead center in the timing hole before you remove the gears to see if the hole and slot are mis-aligned on the breather. If you find them to not be lining up correctly it is going to make you feel a lot better re-doing all of that timing business. Let me know how it goes......pg
I have been thinking about your last post and I have a question regarding this:
'So I remember the oil pump has to go in with the cam cover off. I Left everything in place, ran the crank around to the advance mark and slipped the breather in so the timing dot was facing out and finished off theoil pump installation.'
Do I understand you to say that you have not removed the pinion gear and drive gear for the breather gear before? Instead you rotated the engine timing mark to line up in the timing hole center, and then inserted your oil pump into place? The breather tube would have to have rotated, leaving the small hole in the breather facing outward. This small hole should be centered in the notch of the bushing, rather than be just facing outward.
If that is the case, things may be a little different with the engine installed in the frame. In the frame you cannot drop the oil pump out the bottom. To re-time the breather you will need to remove the pinion gear and the spiral gear behind that. The pic of the tool needed to take the pinion off is shown below. The lip edge on the half round catches the backside of the pinion teeth and pulls the gear off the shaft. As I said, I have made a puller at home in the shop.
If you need any help on getting the pinion off just let me know..........pg
[IMG]local://upfiles/8331/55497A32C6C8469F9FCB885356C7ECFC.jpg[/IMG]
