Ironhead A place to talk about Ironheads.
clutch adjusting
Old Dec 24, 2007 | 01:08 PM
solitaryman54's Avatar
solitaryman54
Default clutch adjusting
I was looking through v twin mag before and I came upon a bushing called a tamer for 80 sporty its supposed to stop the bike from lunging an d shift easier etc. has anyone put one on? and if so does it work. I hate to buy one for 45 bucks and its a piece of junk thanks larry
Old Dec 28, 2007 | 07:56 AM
red76harley's Avatar
red76harley
Default RE: clutch adjusting
best money you will spend on the sportster. A lot of bikes will either creep at a stop light while in gear with the clutch lever pulled ( try reving the trottle) or if you adjust the clutch so this doesnt happen then it slips at higher RPM.. its either one or the other. with the tammer, you can adjust the clutch so it doesn slip at higher RPM's and it will now not creep...
It doenst help with shifting at all.. A EZ pull clutch asset will though, again about 50 bucks
Old Jan 2, 2008 | 11:33 PM
cswanson's Avatar
cswanson
I bought and installed a Tamer II on my 71 XLCH. I had to do a little modification to it in order to get it to fit... the outside diameter was slightly larger than the indention in the clutch plate. After modifying it to fit (I used a slight bit of grinder work along with some sandpaper to smooth things out again) I found that it didn't change my surging problem or my inability to shift it into neutral with the engine running while stopped.
red76harley do you happen to have any more information about the EZ Pull Clutch? I'm curious how that might cure the surge problem.
Thanks,
Chris
Old Jan 14, 2008 | 06:17 PM
sqdealgeorge's Avatar
sqdealgeorge
Its a good investment
AlanStansbery
EVO
Nov 4, 2016 05:15 AM
Booey424
Oct 20, 2013 11:54 AM
TexasBikeBoy
EVO
Jun 23, 2012 10:34 PM
'65 Billy
Sep 18, 2010 09:54 PM
freebyrd
Jun 6, 2008 09:22 PM
