Ironhead A place to talk about Ironheads.
curious
Old Jan 15, 2008 | 12:43 AM
shovel pat's Avatar
shovel pat
Default curious
can somebody help me identify this for year and model?
Old Jan 15, 2008 | 01:14 AM
piniongear's Avatar
piniongear
Default RE: curious
ORIGINAL: shovel pat
It is an XLCH.
It has what apears to be the polished strip down the middle of the timing cover.
It has the oval center mount oil tank.
It has the Fairbanks-Morse magneto.
It has the solo seat with the 2 rods supporting it going into the frame tubes.
It has the rubber boots on the forks.
It has the early front fender with the long braces at the fender ends.
All of the above features would tell me that it is somewhere between a 1958 and a 1962.
And it may well be, but the front brake hub looks like it is full width aluminum. If that is true, then the wheel is from a 1963 or later. A 1962 or earlier CH would have a front brake like the 1957 XLH model photo I have attached. This was a narrow drum made of steel........pg
[IMG]local://upfiles/8331/D159D179141841068EA3EBF90530A18B.jpg[/IMG]
Old Jan 15, 2008 | 06:30 AM
nywarthog's Avatar
nywarthog
Default RE: curious
If it's original, a full width front brake makes it a '64 or later, early style mufflers make it a '65 or earlier. I can't remember when they introduced the stamped steel oil tank, '64 or '65, so it's a '64 or '65.
sgr60
EVO
18
Jul 14, 2018 07:19 AM
SparkyRidesAgain
Shovelhead
Apr 12, 2011 07:54 AM
dldlaw
Flathead
Oct 29, 2010 06:59 PM
C. Numb
Ironhead
88
Dec 31, 2009 09:29 AM
Whiskers
Dec 7, 2007 08:21 AM
