Ironhead A place to talk about Ironheads.
Vapor lock
Old Feb 12, 2008 | 02:10 PM
Racer_Rick's Avatar
Racer_Rick
Default Vapor lock
Anyone ever had a problem with this? I seem to have one. Whenever I get a warm enough day I have to stop & blow in the tank to get fuel to flow again. A friend (Harley mechanic) said it is a part of my mid range troubles & I should look into a Pingel petcock. I'm looking forward to summer riding but not if I have to stop every 20 miles & blow the tank! Any ideas/sugggestions/someone using a aftermarket petcock?
Old Feb 12, 2008 | 02:54 PM
83XLX's Avatar
83XLX
Default RE: Vapor lock
Sounds more like your gas cap vent is stopped up, orsomeone replaced the vented cap withan unvented one. If that's not the problem, take your petcock off and see if the screen is stopped up (highly unlikely). I'm using an aftermarket petcock, but it's just an OEM-style replacement. It flows plenty of gas - there's no need for a high-flow petcock on a fairly stock Sportster.
Old Feb 12, 2008 | 03:07 PM
Racer_Rick's Avatar
Racer_Rick
Guess I should have mentioned. 1200CC engine with bigger cams too. I tried the gas cap vent, it's working OK. Just replaced all the hoses on the tank & the filter as well. When it does it the filter has no fuel in it, blow in the tank & it then shows some fuel. Might have junk in the tank though, I'll pull the petcock & clean the tank tomorrow
Old Feb 12, 2008 | 03:41 PM
DeJavu's Avatar
DeJavu
I've had a similar problem on my Evo. After it sits for a while I can see thru the clear fuel line that the gas is below the carbfloat valve height. Nothing but air all the way up to the petcock. Not sure why, nothing wrong with the gas cap or petcock. Come on Techies help us out here.
challutz
Mar 16, 2015 09:56 PM
Racer_Rick
Ironhead
19
Mar 21, 2008 11:15 AM
83ironhead
Exhaust System Topics
Oct 21, 2007 01:34 PM
Trash Rat
Aug 31, 2007 06:08 PM
zenwarrior
Jul 17, 2006 01:30 PM
