Ironhead A place to talk about Ironheads.
68 xlch,is electric start possible????
Old Apr 3, 2008 | 02:45 AM
sunny68's Avatar
sunny68
1st Gear
Default 68 xlch,is electric start possible????
can you swap cases with an xlh???any input would be greatly appriciated!
Old Apr 3, 2008 | 05:17 PM
piniongear's Avatar
piniongear
Default RE: 68 xlch,is electric start possible????
In a word.....NO.
It could be done, but you will have to have a matched set of cases. Then there is the problem of the frame dimensions. When they made the new primary in 1968 for the XLH the starter motor needed more orrm, so the factory added a small amount to the frame to accomodate the starter and the huge battery needed to turn over the starter. So, practically speaking, it is not possible.
If you want an electric start Sportster, you need to look for another bike......pg
Old Apr 3, 2008 | 07:35 PM
sunny68's Avatar
sunny68
1st Gear
no biggie,just wondering...how do you feel about magneto?is it hard to convert to a battery?what are the pros and cons?THANKS!
Old Apr 3, 2008 | 09:27 PM
piniongear's Avatar
piniongear
I like magnetos. I used them for years. If I had an early Sportster with a magneto, I would not part with it for any amount of money.
Magnetos are becoming rare.
They give a good spark.
There is little maintenance other than the points with a magneto.
As to the advantages for converting to a circuit breaker (battery ignition) I cannot think of a reason to do that.
Some of the dis-advantages include:
You have to find a circuit breaker to buy.
You have to run wiring that you do not need with a magneto.
You have to wire in an on/off switch.
You have to depend on a good battery to get the bike cranked.
Dead battery= NO START.
Starting to get the picture?...........pg
Old Apr 3, 2008 | 10:04 PM
sunny68's Avatar
sunny68
1st Gear
hey pg,your alright,i just got my first "oldschool" bike (68 xlch chopper) after i got it,i started reading ironhead horror stories and got a case of the o *****,then i stumbled onto some of your posts and its obvious your the "ironhead yoda" i've read alot of your posts and its made me feel good about it again,so THANKS.
Old Apr 3, 2008 | 10:43 PM
piniongear's Avatar
piniongear
Oh yeah sunny68, you have a good bike there. One of the really old ones, and if it is the original magneto then it is a CH engine.
Keep all of the equipment it has on it, just like it sits. Then get it running sweetly and well tuned so that it starts easily. That will keep you busy for a while.
When you reach that point, just ride and enjoy your set of wheels. There are not many riders who have to use a kick starter to fire off their machine. You will draw a crowd of lookers when you do.........pg
jayrivera16
Mar 16, 2018 05:36 AM
hvywghtchamp
Electrical/Lighting/Alarm
23
Aug 28, 2017 10:10 PM
Krazyshark
Ironhead
Nov 18, 2011 02:31 PM
fxdxrider
Ironhead
13
Sep 28, 2009 11:40 PM
bigredflhtc
Ironhead
19
Nov 30, 2008 07:38 AM
