Ironhead A place to talk about Ironheads.
79' elec. problem
Old Apr 8, 2008 | 04:03 PM
scooterhead's Avatar
scooterhead
1st Gear
Default 79' elec. problem
I went for a putt on sat. pulled up to the house and flipped my run/stop switch to the off position..with the key still on.went inside..came back out 20 min. later and tried to start er up and all i had was a headlight/taillight..i just bought a new battery this year..any sugestions would be helpful..thanks.
Old Apr 8, 2008 | 04:36 PM
supr2nr's Avatar
supr2nr
Default RE: 79' elec. problem
Did you leave the lights on while you were in the house for 20 minutes and then came back out and tried to start it? If so then you may have drained the battery enough to run the lights but not crank the motor. The battery needs about 12.5 volts to turn over the motor. Try first hooking the battery up to a charger and letting it charge for a few hours. Then crank it back up.
Kevin714
Nov 25, 2016 08:17 PM
bocody
Mar 9, 2015 09:43 AM
sfad
May 4, 2014 10:36 AM
nighty0619
Apr 6, 2014 12:25 PM
tonyvisone
Feb 25, 2013 03:55 PM
