Ironhead A place to talk about Ironheads.
kickstart slipping through
Old Apr 14, 2008 | 06:50 PM
csd4682's Avatar
csd4682
Default kickstart slipping through
I have a 1975 kick only and have started experiencing the "sportster knee" man does that hurt, anyways sometimes its just slipping all the way through. how hard is it to replace the components? I found the kit on zoom cycle, what all do I need? I dont really want to have to buy the whole kit if I just need acouple of parts. I feel pretty mechanically sound, but im not comfortable opening up the engine case, will that be required to repair this?
Old Apr 18, 2008 | 04:55 AM
csd4682's Avatar
csd4682
Default RE: kickstart slipping through
No takers? Im sure someone here has had to replace the kickstart ratchet assembly. Any help or advise is very welcome.
Old Apr 18, 2008 | 09:57 AM
eglideic's Avatar
eglideic
You have to remove the primary cover and remove everything you see in there to get at the back of the clutch drum. Then check the ratchet plate, the ratchet gear and bushhing carefully. Make sure the gear is good and the bushingis stillfairly tight. You might want to take them all to an experienced mechanic to tell you which parts need replacing. Also check over the starter shaft and gear. The shaft maybe bent or twisted from yearsof use.Now is the time to replace them if needed. Tally up the parts that need replacing and then you'll know if you should buy a whole kit or just one or two parts that are bad. Then when all the bad parts have been replaced, put her back together.
Old Apr 18, 2008 | 11:29 AM
Moon Wolf's Avatar
Moon Wolf
It's not too hard. I did one just last week. You do have to rivet on the ring behind the clutch hub.
It's not always the ratchet, though. Sometimes the clutch hub bearing itself can cause the problem.
The gear in most of the kits is a little different from the oem part, so inspect it carefully, and replace only those parts that need replacing. The wear should be fairly obvious.
Old Apr 18, 2008 | 07:37 PM
SportsterBob's Avatar
SportsterBob
I had an issue with the ratchet plate rivets on the clutch drum loosening up and causing the ratchet plate to "flex" while kicking the motor over....Your best bet is to pull it apartand inspect the parts before sinking money into the problem.....It may result in down time but living on a budget like many do in here beats the crap outta throwing money away.
Old Apr 19, 2008 | 06:11 AM
csd4682's Avatar
csd4682
yeah, im not in the business of throwing money away. I will waint untill a rainy weekend to tear it down and see whats going on.
gauthier6916
Sep 19, 2016 09:13 AM
pqct01
Shovelhead
Jun 22, 2014 07:48 PM
OlGrampy
Ironhead
May 1, 2011 09:34 PM
ironside67
Ironhead
Apr 7, 2009 07:04 PM
TIPN8R
Jul 17, 2007 07:48 AM
