Ironhead A place to talk about Ironheads.
Average MPG
Old May 8, 2008 | 01:54 PM
supr2nr's Avatar
supr2nr
Default Average MPG
So I wanted to lighten up the mood around this place a little bit and start a thread just for fun. Seems like there have been a lot of question/problem threads on here (which I have started my fair share), so I thought I would start this to get peoples minds off troubleshooting and worrying. I would have started a poll but I don't have privelage to do it.
So on with the question. Just for fun I thought I would ask what MPG you guys are getting and what type set up you have. Meaning what type carb, what size bore, and what year. I'm sure that everyone would like to know since the huge increase in gas prices.
I'll start:
Average 35 MPG. It's a 76, with a Mikuni VM38, and it's bored 10 over.
Old May 8, 2008 | 04:54 PM
83XLX's Avatar
83XLX
Default RE: Average MPG
I can get close to 50 mpg on the highway most of the time. I've never checked it around town. 1983 XLX - stock bore - stock carb with larger jets, accelerator pump kit, choke plate removed - SE air cleaner w/K&N filter - stock header w/crossover, Dyno Power mufflers - 23/49 sprocket combo.
Old May 8, 2008 | 05:57 PM
98glider's Avatar
98glider
I have a 84 sporsterbobber with a s&s carb I don't have a speedometer and ran out of gas alot and it seems to suck up gas when you don't know the mileage.
Old May 8, 2008 | 06:40 PM
xxxflhrci's Avatar
xxxflhrci
1977 with stock carb, bored .030 over, runninga noname morefree flowing than stockair cleaner backing plate and a UNI foam filter, and drag pipes. With one size larger than stock gear on the front, I get around 50.
Old May 8, 2008 | 08:06 PM
supr2nr's Avatar
supr2nr
Yah I suppose I should have said that mine was city driving. A lot of stop lights between home and work!
Old May 8, 2008 | 10:58 PM
85RoadsterXLS's Avatar
85RoadsterXLS
Stock 85 Roadster. 50 mpg combination highway/in town.
Old May 9, 2008 | 05:40 AM
sepixlh's Avatar
sepixlh
42 mpg with Mikuni 42HSR...
Old May 9, 2008 | 05:46 AM
Scarletthehog's Avatar
Scarletthehog
1977 sportster, stock carb. (keihin)with K&N air filter and fatbob tank. 50 mpg.
[IMG]local://upfiles/27198/95FE87542B2044BC984AF35EBED2D132.jpg[/IMG]
Old May 9, 2008 | 10:55 AM
Boattrashbill's Avatar
Boattrashbill
84 , 30 over , S&S super e , i toned down the jet size , and dont really remember what size right now because i have sometimers. havent checked the mpg in awhile , but the last time checked it was getting 43mpg on the hwy , and running at any speed over 70 you might as well unscrew the petcock and let it drain out.
Old May 9, 2008 | 07:00 PM
SportsterBob's Avatar
SportsterBob
The best I ever got out of the 'ol 900 was 50-mpg HWY at a consistent 60-mph.....S&S "B", stock "P" cams, 23-tooth front sprocket, mag ignition, ported heads (more like hogged out), Manley stainless valves, no passenger, a sleeping bagand sober.
