Ironhead A place to talk about Ironheads.
Help!
Old May 16, 2008 | 09:59 PM
supr2nr's Avatar
supr2nr
Default Help!
While the bike was awaing a part to get it running again. I figured now would be a great time for me to fix the front wheel bearing which has been squealing slightly. While I'm removing the wheel I notice that one fork is not uncompressing as it should. Now this is not a HUGE deal as I can just compress the other fork while I'm putting the tire back on, but obviously this is going to cause a problem because without it uncompressing its not going to recover from a bump or obstacle as it should.
Anyone ever experience this and if so how in the world did you fix this? Should I just heat the sucker up and then "gently persuade" it to move down and then refill the fork oil.
Old May 16, 2008 | 11:21 PM
supr2nr's Avatar
supr2nr
Default RE: Help!
nevermind I got it. Now I just need to see what type of oil I can use. I realize that the manual says HD fork oil type 4 or 5, but I gotta find what substitutes for that.
Steel Steed
Jul 9, 2012 06:59 AM
vinzilla
Mar 18, 2012 01:25 PM
missedem
Jul 6, 2011 01:35 AM
harley_jeff
Jul 25, 2010 10:52 PM
Desertdog7
Apr 1, 2010 11:04 PM
