Another Screw up from the Previous Builder!
That's right..........it's a whole friggin 180 degree's off. I assume that the only way to fix that is to pull the motor and drop the oil pump. Usually not a big deal, but I have run out of money and time. New baby on the way and I really have no more time left to tinker for the summer. So it's just going to have to run like this until this winter when I pull the motor to paint it.
Just friggin ticks me off. This guy I bought this bike from was the absolute worst mechanic ever. He just did what ever he wanted to get the job done. So far, wiring was a hack job, oil pump not lined up right, wrong size bolts are used everywhere, he would loose bolts and then just use a different type or different looking bolt all together just to save time (thats not a huge deal since they would fit, but it drives me nuts they don't look alike), paint job was all screwed (and as you can see he even painted the inside of the motor!), and he stripped bolts from over tightening just to try and stop a leak instead of doing it the correct way by sealing it up with thread locker or thread sealer. Scares me to even think of what it would look like on the inside of the case if I opened it up. [:@] ooooo it just ticks me off!
Sorry to hear of the discovery of the former owners neglect. That is what happens to a lot of machines. People just do not know what they are doing, but they do it anyway.
You are correct in saying that the solution is to remove the engine and then the pump.
However, I believe there is another way to do it, the problem being it takes a special installer/removal tool to remove the pinion gear.
If you could remove the pinion gear, then all you have to do is slip off the oil pump spiral gear behind the pinion and rotate the breather valve tube 180 degrees from where it now sits and you would be in business.
The last time I rebuild my engine I did not have this special tool, so I just made my own at home. The only tricky thing about that is the threaded end that threads into the mainshaft is a 5/16-24 Left Hand Thread. I had to buy a left hand tap and a die, but after that I had the tool.
I included a photo with the different parts needed to make this tool. I took the pic and labeled it after making the tool so that I could easily explain to others how this tool can be made at home. Hope it helps you some.........pg
edit note: This tool as shown is used to install the gear back in place. The fit of the gear is a fairly heavy sliding press fit. To remove the gear, there are a few more pieces not shown, but you can also use any type of puller, as long as the arms will get behind the gear. Also, be sure to protect the center hole in the crankshaft!!! You do not want to damage that or the left hand threads inside the shaft.
[IMG]local://upfiles/8331/0393E608343C4B23AEB870DE48F13BD3.jpg[/IMG]
Thanks again PG. You always seem to come along and help me out and I really appreciate it.
I know I made mine in 1996, so that was 4 years before I had a lathe. In other words, I made everything with hand tools in the shop.
Let me go up in the attic to see what I can find related to this tool tomorrow. If I can find the thing, I will be glad to ship it to you for your use to get the gear off and then back on. I haven't seen the tool since I last used it in 1996-1997, but it should be there. I will ping you with the results of the search...........pg
[IMG]local://upfiles/8331/AD29AD435270439F978A543237D3BE3A.jpg[/IMG]
[IMG]local://upfiles/8331/E61FEB8F8D7B464E802DF7BB19B22E41.jpg[/IMG]
Here is some pics ( by Affe) how he did it
http://www.saunalahti.fi/~affe2/hdlo...tml#1150288340
It would be easy to install it backwards if you were not aware that it needs to go on correctly.............pg
Sorry, but it may have been used for parts for building another type of tool since I made it so long ago.
The fellow who bought one from Vintage Twin and reworked it to make it fit means VT sells the tool, and that may be your best bet. Finding one on Ebay would be a miracle! This is a single purpose tool.
J&P sells the Jim's puller, but it is really expensive at $200.
I will post a response if I happen to find it...........pg
$120 for a good tool is cheap compared to pulling the engine out again..........pg
I appreciate you and PG willing to send me the tools, and if either of you are willing I will pay you shipping and a few extra bucks for your trouble, and I will have that tool back to either of you very quickly. This is by far the best automotive forum I have ever been on, and I have been quite a few. I used to work on customizing Chevy S-10's a while back and I was part of a forum regarding them and the people there were only concerned about how many street races they won. Never a care about helping another person out or building a nice motor. This is the first forum I have been to where people actually care about helping other people out. I think Pyro said it in another thread here but thank God for this forum!
But if either of you don't want to send out the tool, I think it should be fairly simple to aquire the parts around town and get one built for the removal. I just need a 5/16"x24 left hand tread rod, and a piece to go over the piniongear with a 5/16" nut welded in the middle of it.
Biggest thing that has been reassuring is that everyone here has said I should be able to do it with the motor intact. Thats really good news for me.
Thanks again everyone.
