have 79 xls roadster, bike has always ran great if I could get it to start. guy who owned previous put chinese starting system in. i replaced w/original parts, hardwired everything inside headlight housing, and still couldn't get it to start(among other various electrical problems). have since stripped entire bike and am contimplating relying only on a new kicker to keep the bars clean and avoid any further electrical dilemas. any feedback???
That might not be the easiest thing you have ever done (installing a kick start on your bike)
First off, you have a 1979 model. Did the 1979 come with a K/S lever? I know very little about the models newer than 1974.
This was an oddball year for Sportster. Nothing wrong with the bike, it is just there are a number of things different on it than any other year Sporty.
First thing to check is to see if your frame will allow a kickstart shaft to be used.
Then will the crankcase allow it?
Finally there are a bunch of parts needed to put it all together.
It is a big job if you want to put a kick start on an early model Sportster that originally came with a K/S using a kit for the install.
My understanding is the parts (that are now made in Asia) do not fit together well and it takes a bunch of fitting to make a kit work.
Good luck with the project and let us know how it turns out..........pg
